Can my POS PSU power a 780? (Edit)
I have been wanting to upgrade my current GPU which is a 6870 because it likes to brick itself whenever I go to watch curtain videos depending on what format they are in and I am wanting to upgrade to a NVidia Geforce GTX 780, but I am unsure if my  PSU could handle it (Current psu here) and I don't want to risk burning out my system due to an overload.
EDIT:
I've decided to do what deejeta said because of my cpu and go more for a 770, but I am unsure if I even have the pins to power the GPU unless they normally come with Molex to  8 pin PCI
yes it should be able to handle the new gpu
God no, dont do it!
That unit is rubbish. Keep it as a spare and buy a decent psu. Too many good systems have died doing what you were going to do.
Buy like a XFX, Superflower, Seasonic, Silverstone, Corsair & others.
The reason your old card was failing is probably due to the psu's 12v rail failing anyway.
I never thought that could be the problem before...
Side note: The image of it makes me think that it belongs in McDonald's Play Room.
Those neon green rails are still burnt into my eyeballs...
Will it work... theoretically, yes... but really, if you're worried about it just buy a good PSU... it's a lot WHOLE lot cheaper to replace than a 780... I use Corsair's TX series, if you want one that's modular you can go another route (I don't care if it's modular cause I've got a Fractal Design Define R4 case, and there's room to fit a sumo wrestler in it), and Logan just did a video praising Fractal's PSUs... I've never used it so I'm not going to tell you how great they are... I've always used Corsair, and a lot of people here will swear by Corsair PSUs... so call us all fanboys or take it as we buy Corsair to begin with and don't run into PSU problems later...
It's up to you, I'm not broke, dunno if you are... I'm not afraid to pump money into my computer cause I use it for a lot... dunno if you are... I'd get a Corsair PSU... you can do what ya want man...
I was thinking of getting a Corsair RM1000to future proof and too put into my next build
RM series is good. You really don't need 1000W. Even with hardware many years from now. Everything is gradually becoming much more power efficient.
Most systems only require 450-500W to run comfortably these days.
The one thing that concerns me about your current unit are the 2 12v rails. While it has enough watts, the manner in which the amps are delivered strikes me as poor quality design. A single 12v rail with approximately 42 amps would be preferable
YOU MUST GET A NEW PSU, AND SELL ME THE PRETTY ONE.
Just had a look at your pc specs OP, a AMD A8-3870K will bottleneck a gtx780 really bad. The highest card I would consider would be a r280, gtx760/770. Yeah the grunt of a 780 would be lost to the weak apu.
For the under the price of a gtx780 you could get this >>> http://pcpartpicker.com/user/deejeta/saved/#savedbuild_772539 then when you upgrade the rest of your build all you have to get is cpu/mb and another gtx760 if you need shitloads of gpu power. (2x760's > 1x780ti btw). The selected psu (xfx 750pro - seasonic oem) will handle whatever you could throw at it, has a 5yr warranty and is a really nice unit.
Most graphics cards come with molex to 6 and 8 pin connectors primarily for old PSUs. I do believe you can use one for an additional card in SLI, just that you want to make sure you have enough amps on the rail to handle it.
