I bought a PAAG-ET3114B KVM switch and connected my 4 PCs. It’s a DP 1.4 KVM switch. I used to work with a HDMI KVM switch (TESmart).
Problem I have is that on my laptop the build in screen will activate when I switch to another PC, and I normally disable that build in screen completely, when I have my laptop connected to my KVM setup I want it disabled.
However, switching to another PC will signal my laptop that there are no screens connected and the build in screen will activate.
Also powering up a PC with the KVM port active to another PC will result in the screen not coming on when I switch to the PC just powered up.
On my HDMI setup I did not have this issue.
Does this have to do with EDID config? Can my new KVM switch maybe keep a signal active to my PCs when I switch away from that PC?
This does not work… I tried… It’s not about the windows in the windows desktop.
It’s about the build in laptop screen… That activates because windows/bios detects there are no active screens attached after I switch to another PC.
I want to use my big monitor exclusively when using the laptop… do I disable the laptop screen in the windows display manager… But as soon as I switch to another PC… Poof… the laptop screen activates…
Mirror your display to what exactly? an extra port to the monitor?
My build in screen does not support 4k, so mirroring there wont work. But I suppose I could try to also connect HDMI… Mirror DP and HDMI from my laptop to my monitor and see if that works…
EDIT: tried mirroring and yes that works… however my laptop cannot handle 4K + 4K… It can do 25xx-1440… mirrored… But that resolution doesn’t look sharp enough and is a strain on the eyes.
I can’t read anything there that will help this issue.
Before I had DP and HDMI port both on docking station. The USB-C to the docking station cannot handle 2x 4K resolution. So now I connected DP via docking station and HDMI direct in laptop side. Now I get 2x 4K.
So I duplicated the two in windows display manager. But when i switch back from this laptop (via DP) to another PC, the laptop screen activates again…
However I can select disconnect from windows screen 1 (laptop screen) so now it will stay off even when I switch my KVM to other PC.
Not ideal, but I will give it a go.
Any suggestions regarding a DP EDID injector (or what is it called)? It should do 4K and 60fps… but higher (120 fps or 144 fps) would be great too, if such exists.
How about keeping the laptop lid closed; that should turn off thr internal display, right?
Or, rethink where the laptpp is on your desk, maybe have a laptop mount that places the device where the internal screen would be useful. Just an idea.
