Is there any bracket or something so i can put a cooler that is supposed to be for 775 socket on am3+ socket. it looks like this http://i.imgur.com/4tKT1Aa.png i dont know what its called its an old cooler
Unless you have the brackets for it I would say just spend the 40 bucks on another cooler. Like a Scythe Mugen or Coolermaster Hyper 212.
Sure you can make your of modifications on it, but unless you are handy I wouldn't suggest it.
