I have been using HPE 727021-B21 for some time. I have been using the window server in it. I wanna use Windows 10 in it. My question is can I do that?
Will it work without any problem?
Should I use Windows 10 or Windows 7?
I cannot see any instructions on their website.
I think my manager purchased it from allhdd
It should just run since they use the same or similar windows kernel. Some official software for it might have checks to make sure the OS you are running it one is a server one.
There are no instructions because no one really has a need to run desktop os on a server hardware.
