On a new build I am thinking of running a Corsair H110 in a push-pull config (4 x 140mm fans). I'd like the motherboard to throttle these fans. The motherboard will be a Gigabyte G1 Sniper 5 which has 2 CPU fan headers.
Can I safely use some splitter cables and run these 4 fans off the 2 CPU fan headers?
Thanks.
yes you can, you'll need to find either a fan hub or some fan splitters. Some AIO liquid cooling devices come with Y fan splitters where you hook up 2 fans to one header. I also know that NZXT makes fan hubs for around $12 or so where you can hook up 4 fans to 1 header + 1 molex for power.
I would strongly recommend a fan hub of all, mainly because the 1 cpu header can dictate evenly how much airflow all 4 fans run by. If you use 2 fan headers, you'll have uneven flow and possibly some extra noise from turbulence because of difference fan speeds. I know it's not going to be drastic but every little bit helps.
Thanks Mafisometal - that has been helpful.
