Hey everyone, my Xbox 360 is getting kind of old, and I decided to switch over to the PC world. Problem is, my computer is almost non-functional, and I don't have much money to spend. However, for what I need it for, I think it's easily possible. I only do some light gaming right now, but I want to start recording and editing. That doesn't need to be considered besides that I need an upgrade path for it later. Anyways, here's what I need:
- Budget: $450 max
- Where do you live: Southern N.J (too far away from the microcenter in North Jersey)
- Do you need or already have peripherals? Yes, but I need a new keyboard.
- What will you be using your future computer for: Gaming above all, Netflix/Youtube, I want to start learning how to video edit and program, so something that can do that, or has an upgrade path to do that.
- Do you overclock or want to get into overclocking: I don't really care.
- Do you plan on going for custom watercooling now, or in the future: Maybe?
- OS. Do you need a new one: I'm going to use Linux for now to save money on an Operating System.
- What kind of settings do you like or what FPS do you want to play at: I really want the highest FPS I can get, and I don't care if I have to tone down the settings to achieve that.
- What resolution will you be playing at: 1080, but I have a small monitor that is 720 I might use.
- What kind of games do you like to play: MMO's, Open-world, adventure.
- What specific game will you be playing: MineCraft, LoL, Starbound, Gmod, TF2. I'll probably play some for demanding FPS's later on, so an upgrade path will be next.
If you guys need anymore information, just ask me, I'm glad to help. Also if I could get a somewhat fast reply, that'd be great, I need to buy this asap, so the faster the better.
