Can Anyone Recommend Me A Case?
Looking for a minimalist design, USB ports on the front, MicroATX/ATX, Midtower, Black.
I prefer a a balance of Airflow and Loudness
Something with at least 2 USB 3.0 Headers
Thanks everyone
If you are looking for balance between silence and airflow, the Fractal Design Define R4 or Define mini is a great option. It has sound dampening foam on the inside, and the fan grills/holes have removable foam so you can choose to prioritize acoustics or airflow, plus, fractal's build quality is legendary. Watch Logan's review on the define R4, and Linus has an overview on the define mini. I hope i was of help.
One problem USB headers are on top I need them on the front or it wont fit under my desk I like this corsair one is it any good?
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139018
Anyone?
I really like the look of the Fractal Arc Mini mATX. The USB slots are on the top, though...
Corsair builds decent stuff.  Honestly though, from your description in the OP the first thing that came to mind was Lian Li.  They are known for their minimal styling and have a number of mid-tower cases in various price ranges.  Might be worth a look.
Thanks guys
Do you guys know if this is a good one though, I like it
Btw how bif of a video card will it support?
The Carbide 200r is an awesome case. Here's a very complete review of the case made by OC3D tv:
http://www.youtube.com/watch?v=UgTMIlzmwQ8
And Linus Tech Tips unboxing, he is really gushing about the case (he is wrong about one thing though, you can remove the front bezel, Tiny Tom Logan from OC3D TV will tell you how):
http://www.youtube.com/watch?v=NkuBK9jSvIE
If you want to put the graphics card in the first slot, then you can have one almost as long as the case (44 cm until you hit the fan). If you put it in one of the other slot, then you are limited by the SSD bay (about 29-32, depending if you have SSDs in there or not): http://www.youtube.com/watch?feature=player_detailpage&v=8gpYX3mZ3eQ#t=271
I think I like this a bit better than the 200r,
the 230t
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139026
hey, you may remember me from a while back (pc cpu issues) you did say i could have a $6 of choice, but you never fulfilled your promise. Could you maybe make it up to me now. Thanks
Also dont prented you dont know i got ya skype :P
Oh yea what do you want
You did save my computer after all
just bought this one i love it
http://www.newegg.com/Product/Product.aspx?Item=N82E16811139009
http://digital.gamefly.co.uk/#!/download-portal-2/5003627 if possible its $4 atm (in sale) my steam account is @LewisTaylorDzn if you could add me :)
