can anyone help me with my PC build?
I’m planning on purchasing this pc but with 3600 Mhz ram, should I change my opinion?, I’ll be using it for 1080 p gaming as I can’t afford 1440 gaming rn. and it will cost 786.75 usd.
CPU: Intel Core i5-12400F
Motherboard: Gigabyte H610M H V3
RAM : 8×2 D35G Gigabyte 3200 Mhz
GPU: RTX 4060 gigabyte eagle oc )amd cards are much more expensive in my country than Nvidia(
SSD: Legend 710 512GB
PSU: GameMax 650W 80+ Bronze
Case: Fantech GC83 Rainbow
Cooler: SeaSonic RGB 5400
That looks kinda like a bad deal honestly. These are the US prices (tried to get as comparable parts as possible, but PSU really was too cheap not to get):
PCPartPicker Part List
I would suggest either AM4 or AM5 here, depending on your upgrade plans. If no upgrades are on the table, I would say an AM4 system with 5700X and RX 6600 is the sweet spot for the US market:
If you plan on upgrading some components within 3 years, however, AM5 is seriously the better purchase as it allows you to only upgrade RAM and CPU down the road:
This is from a EU / US centric perspective, mind you. Australia / Asia I have zero clue about pricing.
Also didn’t the 12th gen intel procesors have that high failrate isue. All those systems Wertigon suggest will give you more fun with the new computer
welcome
Looking past performance difference(s), you could probably get the RTX3060 and get more QoL
[12GB // full PCIe x16 comms // better 1+0.1% lows]
One obscure AMD option, would be the 6700 10GB [can be had, only running off 1x8pin]
12th gen’s Alder rather than Raptor Lake and 100, 400T, and 500 in 13th and 14th gen are rebadged Alder. 400 and 400F are a mix depending what landed in the bin.
Interesting, I get no hits on this at all.
