Hey guys, I was just building my PC and I wanted to do some major overclock. I heard the NZXT X60 was one of the best you can get. I was wondering if the NZXT X60 Kraken would fit in my Cosair Cougar Solution case.
This spreadsheet will tell you if your case will fit the X60. If your case isn't listed, the X60 likely doesn't fit without major modifications, unless it's a really new case that NZXT hasn't listed.
