The box for my 270x says I can drive 2 of them on 600w. I bought a Seasonic 80+ gold 650w with intent on doing just that. Making sure after I bought it, I asked reddit. Half of them said I needed 800w, and half said i'd be fine with what I have. Will what I have be enough for a 8320 and a 270x crossfire? Nothing overclocked. Thanks.
a 7870 should pull in the neighborhood of 200 watts at full load, you should be fine
I've seen 8320 and 7870 on 430watt psus, you should be fine.
I am confident that it would run on 650W. A decent 650W can accommodate two larger cards.
*Edited due to bad info on my end,
All of this is incorrect.
if my 750watt can run two 7950s and an overclocked 8150, and in another build, a 280x and a 7950 with an overclocked 4670k, all on max, mining and/or folding, then he will be fine on a 650 watt.
I would also Like to add that the 7850 max TDP is 130Watts. So your calculation of "Almost 300 Watts each" is horribly mistaken.
Cloud, you are wrong. The 270x has two 6-pin connectors. That means the maximum amount of power it can draw is 2x75W (one single 6-pin supplies 75W of power) + 75W (from the PCI slot) = 225W.
If it has two 6-pin it doesn't mean that it uses those at full power. It simply means that it needs more than 150W (1 6-pin and the PCI slot). I saw a review where the 270X was drawing 170W of power.
To summarize: 225W x 2 (the most horrible situation possible, won't ever happen in my opinion even if you overclock it) + 150W from an overclocked processor running at full power (won't ever happen while gaming) = 600W.
A more down to earth use case would be 2x170 + 100 = 440W, a 650W PSU would be below 75% load. You're golden.
Yup,I didn't see that the power draw was for the whole system and not the gpu itself,just noticed after I've read your comments,thanks for the enlightment,I would have ended up with another PSU if it wasn't for you guys. I've read a ton of articles and never noticed that that power draw was for the entire system,lol. Thanks,now I can relax
Glad to have been of use :)
