So I'm gonna build a pc and I'm quite new to it and I have my build and I saw that the motherboard that I'm getting (I think its a ASrock B75M R20) has a micro ATX form factor, I then looked at my case specifications said that its motherboard support is ATX. I wondered wether this motherboard would be able to easily fit in the case or if i would have to buy more stuff or a different case after spending the money. I'm going to order tonight so it would be helpful If i could get a quick answer (even though its not super important, If I'm not sure I'll just order later)
My build if it helps (its a "help" post but still going to be my build)
https://teksyndicate.com/forum/build-pc/pc-build-help-my-first-time-building-pc/170374
Motherboard -
http://www.mwave.com.au/product/asrock-b75m-r20-motherboard-aa34572#detailTabs=tabSpecifications
And without further ado...the case -
http://shop.phasercomputers.com.au/products/xigmatekasgard381blkmtcase
Thanks
****EDIT****
Looked at a few different Websites that said in its specifications that it supports ATX, ITX anndddd Micro ATX.
Thanks for all your answers, I'm thuper duper happy now :D
