Calibrating Monitor Problems!
Hi Guys,
So recently I bought two Hp Pavilion 23xi IPS LED monitors ( http://www.amazon.com/HP-Pavilion-23-Inch-LED-lit-Monitor/dp/B00B3FTM7S/ref=sr_1_1?ie=UTF8&qid=1387138085&sr=8-1&keywords=hp+pavilion+23xi )
And once I had them all set up I noticed that my primary monitor was a lot brighter than the secundairy monitor and the secundairy monitor had a yellowish tint to it. I have tried a lot of things, I have tried getting RGB colors to match, I tried to change the brightnes, contrast everything. And I still can't get it right. I am out of any ideas so maybe one of you guys can help me with this problem?
Thanks a lot in advance!!!!
Greetings from The Netherlands
does it stays the same if you switch ports. i mean plug your secondary where your primary is and vice verso?
if the problem is the same it might be your graphics card, otherwise it might be a fold in the monitor itself.
Please post in the appropriate forum.
Oh I'm sorry man I just wanted to get this over with.. But what is the appropriate place a post like mine?
