So … I got this idea (which is how I always get into trouble),
I’m thinking I’d like something like a steam cache, but for linux distro repos, and I’d also like it to be a time machine for those repos, so you can move forward/backwards/pin the repository, and also a thing where I can ask for a particular version (to bisect issues, when I have time for it).
Debian, for example, already has snapshot.debian.org. - all I’d need to do is cache it, same as steam cache.
ArchLinux has archive.archlinux.org (aka Arch Linux Rollback Machine) - same story.
I don’t think Alpine has this, but I can build it (I kind of did, in my other post it works, there’s some issues I need to solve).
For practical reasons, it’d be nice if I could stick a microSD card into e.g. a NanoPi Neo3-LTS or into a ZeroPI, plug it into a POE switch through a POE splitter, and just have it there as a dongle and just let it run. I want the opposite from a 4U rack supermicro nvme epyc box.
The network port is limiting this to 1Gbps / 100MB/s, and it’s just a bunch of files, average a few megs in size that will be stored - not unlike photos really, probably smaller.
Which microSD card should I use, and what filesystem should I use to minimize the risk of data corruption (really bad and annoying to deal with), or just flat out dying (not as bad)?
In terms of load, I’m thinking maybe between 1GB - 5GB per day of both reads and writes + whatever filesystem metadata stuff.
I’ve had an ok experience running Home Assistant from a Samsung Endurance Pro card- not the fastest, but works.
I also now see Kioxia Exceria High Endurance cards
Are any of the cheaper cards or bigger cards (512G+) good enough to run somewhat of a storage workload on them?
