Cable Help!
Hello Teksyndicate,
I'm about to order a new PC; http://pcpartpicker.com/p/DKXD
Now I am very into my PC's aesthetics and so on! But I'm in alittle need of help due to not being able to figure out what cables I need for my setup, so what I'm asking as a request is for some kind soul out there to put a list of cables that'll be needed for this system to run!
This include, I/O cables - Sata - and so on.
Thanks in advance!
Most of the products come with the cables themselves.
If I were you, I'd look at the compatibility issues below the products you have. Primarily changing the memory.
I ment more like extention cables as I'll be buying braided cables, and the memory does not require any cable x) Was marely a placeholder so to speak.
The RAM and Core are incompatable..change out the RAM for something else.
Read above coment please.
So, do you intend on recycling memory from your current PC then?..If so, why even bother putting the RAM in the pcpartpicker list.
Would you please just answer my question on what braided cables are needed for the system?
BUY ALL THE CABLES!!!
about 15 to 20 cables
Corsair have some braided PSU cable kits available in black/white/red/blue. Get sata cables in a color you like. Hope you are planning on painting the fans because they look ridiculous. Quad chanel memory maybe. Also if you are willing to wait a bit you should go with the Swiftech H220 instead of the H100.
Awmagad! Thank you Chunk! Just the answer I was looking for. many luffs to you.
The RAM is compatable. I have 16GB of G.SKILL Trident X 2400mHz, which is rated for 1.65V, running with my i7 3770k. Pay no attention to the warning that PcPartPicker is giving.
