Cable help
hey i have built my new gaiming rig the amd FX 6300 thansk for the part sugestion but yaah i have all the important cable connect to the point i can game on it and use it for everyday use but i cant figure out how to plug de hardrive led and the other cable like that and also the case fan led and a other thing that not related to the question is that the ethernet controller diver and two Universal serial bus (USB) controller driver cant be install any sugestion to fix this
download the Ethernet drivers from the motherboards website, get the chipset drivers from the AMD website, HDD light gets plugged into the motherboard next to the power and reset buttons, it may be on backwards causing it to not light up, fan LEDs sometimes plug into a molex plug of there may be a switch somewhere on the case to turn them on and off
