C13 power cables - is it safe to plug these live?
Hi all,
This is probably a daft question, and due to being daft, I’m expecting the answer to be a “yes, it’s OK”.
Over the years I’ve been pedantic of plugging C13 cables when the UPS is off. However, if I my load device has an on/off power switch (say another PC), is it safe to plug the female end of the C13 into a running UPS?
Since the load is off, there wouldn’t be any sparks due to rubbing contacts?
Of course, I’m sure there are a few folks that have:
  • Kept the load switch on, and plugged the female end into a live UPS
Now, with PCs this isn’t a huge issue as a PC starts up in standby and only the 5vdc supply is mainly loaded etc, but what if you have a bigger load that has a high inrush current - would you see sparks/frying if attempting the above?
Thanks,
Mike
It’s best not to fuck with electrical current. Follow whatever instructions your UPS’s guide says to do.
As safe as plugging the male end into the device. Or as plugging the device into a wall socket.
If a PC PSU is on, even if the device itself is off, it’s possible to get a small spark as the capacitors charge rapidly, but it’s more on the initial contact than on rubbing. You can always mitigate this by turning off the PSU and I believe most newer ones have built-in inrush current limitetrs anyway.
Same as plugging into wall socket, really.
