C++ map menu class, return int to main switch-statment. need help
class Menu {
private:
	const map<string, int> menuChoice = { { "analize",1 },{ "load" ,2 },{ "save",3 },{ "exit", 9 } };
public:
	int inputValidation(string usrChoice)
		int temp;
		auto validateUsrChoice = menuChoice.find(usrChoice);
		if (validateUsrChoice != menuChoice.end()) {
			temp = menuChoice->second;
		return temp;
int main()
	bool runPrg = true;
	do {
		string usrInput;
		Menu menu;
		cout << "\tMenu: Analize file : 1 \n\t Load : 2  blblabla ...\n\t" << endl;
		cout << "\t";
		getline(std::cin, usrInput);
		int c = menu.inputValidation(usrInput);
		switch (c)
Hello again guys, edit my post!
brb with error msg’s. But the problem is this part: " temp = menuChoice->second; " , i cant get it to work. The thing is that i dont really know how .find works… is it so that the compiler adds iterators and doing most of the work/coding behid the sceen?
Ive tried that and also " temp = menuChoice.second; " , didnt work either!
stick your code in three grave marks on both sides to improve formatting.
ex.
code
And the problem is…?
You don’t mention what the problem is, but two things that might be a problem are:
  1. the temp variable in inputValidation is not initialized, so if the item isn’t found in the map it might contain anything.
  2. you use std::cout, std::endl, etc… but you also write just map, and not std::map. Unless there’s a using declaration hiding somewhere, it might not compile.
Hello, never mind, I added “using namespace std;” , in a atemp to clear up the code a bit for my newbie eyes!
The problem is that i dont really know how .find works. How to store the “pointer value - to deref” or how i then store the second elements to something" if it even works like that?
Also i dont really understand: " -> " , is that like a function pointer?
And last, “.second” dosent work either, and i think this is the thing. The way i did it, if .find finds the string in this case, it returns a iterator? but how do i use that?
Here is the different errrors:
cod
Here is an example that looks like my code(or almost identical):
#include <iostream>
#include <map>
int main()
    std::map<int,char> example = {{1,'a'},{2,'b'}};
    auto search = example.find(2);
    if(search != example.end()) {
        std::cout << "Found " << search->first << " " << search->second << '\n';
    else {
        std::cout << "Not found\n";
From: http://en.cppreference.com/w/cpp/container/map/find
So i belive that maybe this dosent work “->” when im trying to use it in the same class?
'Best regrads!
Comment: This is how it looks now, when i did it my self?! :S
And maybe thats good, to be honest, because its the first time ive used a iterator hehe
I gues this is what the compiler does for me when i use the find-member function?
for (map<string, int>::iterator it = menuChoiche.begin(); it != menuChoiche.end(); ++it)
if (usrChoiche == it->first)
temp = it->second;
LOL i found the bugg in my code:
None working solution:
auto validateUsrChoiche = menuChoiche.find(usrChoiche);
if (validateUsrChoiche != menuChoiche.end()) {
temp = menuChoiche->second;
Working solution:
temp = validateUsrChoiche->second;
a -> b is the same as (*a).b. Both behave the same, but the first one is much more readable, especially when going deeper: (a->b->c)
find returns an iterator. The iterator’s contents can be accessed as if it was a pointer: *iter. Don’t forget to make sure the value was actually found, by checking that iter != yourMap.end()
Aight! So in this context its a way to deref whats the pointer(aka iterator) is pointing at(map object) first/second.
So .second and ->second is the same way…
But in another context it could be(i think ive asked it earlier in this thread) a function pointer? A pointer to another class member-function, right?
I think you are mixing up function pointers and functions of pointers to instances. If A is a class with a function b and a is an instance of class A then a->b will invoke b.
class A {
    void b() { ... }
void main() {
    A *a = new A();
    // invokes b
    a->b();
    // same thing
    (*a).b();
Neither a nor b are function pointers though.
Perfect! Thanks alot, think i got it now! Never used this before and this was so unclear to me…
Thanks again!
