Hey guys! I am taking a level 1 C++ course online and have gotten to two-dimensional arrays. I have come across a problem I cant solve and was hoping to get some help. The prompt is as follows:
"(Compute the weekly hours for each employee) Suppose the weekly hours for all employees are stored in a two-dimensional array. Each row records and employee's seven-day work hours with seven columns. For example, the following array stores the work hours for eight employees. Write a program that displays employees and their total hours in decreasing order of the total hours."
You can actually display code using the following...
#include <iostream>
using namespace std;
const int NUM_OF_EMPLOYEES = 8;
const int NUM_OF_WEEK_DAYS = 7;
//Function to sum up the hours worked by a employee
double sumHours(const double m[][NUM_OF_WEEK_DAYS], int empNum)
double sum = 0;
for (int i = 0; i < NUM_OF_WEEK_DAYS; i++)
sum += m[empNum][i];
return sum;
int main()
//Declare variables
double matrix[NUM_OF_EMPLOYEES][NUM_OF_WEEK_DAYS];
double empHoursWorked[NUM_OF_EMPLOYEES][2];
double maxHours = 0;
double maxEmp;
double tempEmp;
double tempHours;
int maxIndex;
//Set employee numbers into empHoursWorked array
for (int i = 0; i < NUM_OF_EMPLOYEES; i++)
empHoursWorked[i][0] = i;
cout << "Enter a " << NUM_OF_EMPLOYEES << "-by-" << NUM_OF_WEEK_DAYS << " matrix row by row where each row represents a employee and each column represents" << "\n" <<"the hours worked by that employee on each day of the week starting with Sunday \n";
//Cin matrix array
for (int row = 0; row < NUM_OF_EMPLOYEES; row++)
for (int column = 0; column < NUM_OF_WEEK_DAYS; column++)
cin >> matrix[row][column];
//Add the hours worked and set them into the empHoursWorked array
empHoursWorked[i][1] = sumHours(matrix, i);
//This is the part that is supposed to put it in the correct order but I can't get it to work
for (int j = i; j < NUM_OF_EMPLOYEES; j++)
if (empHoursWorked[j][1] > maxHours)
maxEmp = empHoursWorked[j][0];
maxHours = empHoursWorked[j][1];
maxIndex = j;
if (j == NUM_OF_EMPLOYEES)
tempEmp = empHoursWorked[i][0];
tempHours = empHoursWorked[i][1];
empHoursWorked[i][0] = maxEmp;
empHoursWorked[i][1] = maxHours;
empHoursWorked[maxIndex][0] = tempEmp;
empHoursWorked[maxIndex][1] = tempHours;
maxHours = 0;
maxEmp = 0;
//Print the employee number followed by the number of hours worked by that employee
cout << "Emp: " << empHoursWorked[i][0] << " Hours worked: " << empHoursWorked[i][1] << "\n";
system("pause");
return 0;
Just a couple things...
double really isn't necessary here. (unless you need to track the employee's time down to the nano second. (use float)
You should use pointers when calling functions with arrays instead of putting the whole array onto the stack. Try this...
float sumHours(float *week)
float sum = 0;
for (int day = 0; day < NUM_OF_WEEK_DAYS; day++)
sum += *week[day];
return sum;
You can use #define instead of the const int at the top of the document.
avoid one letter variables in your loops (makes it easier to select and replace later)
is that insert sort? The best way to fix a sort is to go step by step manually and write down what is in the array as you go. (basically, debug carefully)
I used double because I just wanted to make sure that numbers didn't get truncated when added if they contained a decimal.
I don't know anything about pointers yet and I don't know if the class I'm in will go over them, unless they are part of the object oriented part of it.
I didn't know that but good to know.
I usually don't but I was trying to get something that functioned and then clean it up.
I don't know what kind of sort it is. I was just trying to think of something that would work. The idea was that the first loop would change the start row for the second loop each iteration and the second loop and if statement would find the largest number and then move it and its corresponding employee to the position the loop started in. ninerdelta pointed out where my problem might be. I'll change if(j==NUM_OF_EMPLOYEES) to if(j==NUM_OF_EMPLOYEES-1) and see what happens.
Trust me... you're fine with float. A double is a "double precision float" and is 64bit. A regular 32bit float is capable of holding 7(average) significant digits. That's more than enough precision for counting seconds in a year.
Ok. One thing at a time then. Just be aware than pointers are an integral and powerful part of C code. (no, they aren't an object-oriented-programming thing.)
Sorting algorithms are pretty well established in the comp-sci world. Just pic one and find some pseudo code to guide you.
Thanks for your help. I finally got it to work. There is some really useful information in what you provided and I'll be sure to look over it some more. I'm trying to get my associates in system administration right now and had to take a level 1 programming course. Seeing as I want to learn how to make games in Unreal Engine I though C++ would be a good choice. So far most of it hasn't been any harder that HTML or CSS but I'm sure it'll get much more complex. Here is the code I finished with(changed doubles to floats, I also tried using #define but it didn't like it.):
#include <iostream>
float sumHours(const float m[][NUM_OF_WEEK_DAYS], int empNum)
float sum = 0;
return sum;
int main()
//Declare variables
float matrix[NUM_OF_EMPLOYEES][NUM_OF_WEEK_DAYS];
float empHoursWorked[NUM_OF_EMPLOYEES][2];
cout << "Enter a " << NUM_OF_EMPLOYEES << "-by-" << NUM_OF_WEEK_DAYS << " matrix row by row where each row represnts a employee and each column repesents" << "\n" <<"the hours worked by that employee on each day of the week starting with Sunday \n";
//Cin matrix array
//Sort array into decreasing order
for (int i = 0; i < NUM_OF_EMPLOYEES - 1; i++)
float currentMin = empHoursWorked[i][1];
float currentMinEmp = empHoursWorked[i][0];
int currentMinIndex = i;
if (currentMin < empHoursWorked[j][1])
currentMin = empHoursWorked[j][1];
currentMinEmp = empHoursWorked[j][0];
currentMinIndex = j;
if (currentMinIndex != i)
empHoursWorked[currentMinIndex][0] = empHoursWorked[i][0];
empHoursWorked[currentMinIndex][1] = empHoursWorked[i][1];
empHoursWorked[i][0] = currentMinEmp;
empHoursWorked[i][1] = currentMin;
system("pause");
return 0;
This is called a "Pre-Processor" command ... aka a macro. When the compiler reads the code file and once it parses these lines, it always replaces "NUM_OF_EMPLOYEES" with "8" in the code before compiling. I makes it just like as if you had typed "8" down in your code. It's very efficient.
