About 20 minutes ago my PSU started a high-ish pitched buzzing which I decided to investigate while installing a new hard drive. It is a new Thermaltake Tough power gold 850W which I installed into the system I build almost a week ago (post pics soon :) ). As I took off the back panel, a strong electrostatic shock occurred between my fingers and the backplate (I hastily rebooted and everything works fine) so I unplugged the PSU from the wall. The buzzing stopped after about a second but as soon as I plugged it back in with the power supply switch in the off position, it started up again. It got a slightly higher pitch when I put it into the on position. After leaving it unplugged for about 5 minutes I plugged it in and the noise never returned.
I unplugged it and am using my laptop to write this now. My question: Is the power supply safe?
Any help/insight would be appreciated.
Thanks,
Luke
EDIT: After 10 minutes of it being plugged in but the psu switch set to off, the buzzing has returned but it is very quiet
