My dad is running an iPhone 5s and while it’s a perfectly good phone the screen is a little small for his aging eyes and big hands. He’s also not the most tech-savvy and has little patience when it comes to responsiveness.
I was thinking of buying him a used iPhone 8 from Amazon for fathers day but I wanted to see if anyone else had some good suggestions. I’m worried that he won’t be able to use the swipe navigations on the newer iPhones.
Depending on his dexterity and your budget maybe even consider getting the plus model for the added screen. And then in iOS enable larger text sizes. And maybe zoom viewing.
Get an iPhone 8 plus but make sure you check out the vendor… Anything amazon fulfilled usually is a bit better but even if its not you do protect yourself because amazon fulfilled it… Also make sure its compatible witH the network of your parents… Which network do they use
