To make a long story short; I like the ft05 from silverstone, for the chimney design. But I am not shure if I can use a NH-D15 (noctua) with the included fans. I am planning to get the version without the window, so I will have more clearence. The Silverstone site says that it shouldn't fit, but several (old) treads on multiple forums say otherwhise.
I want to know if anyone has any experience with this combination, or can suggest any other good chimney-style cases, other then the rv05, which I do not like for the looks.
The "other forum" I was talking about are treads on multiple websites like ltt, where the last post was half a year ago. So this is why I wanted to make a new tread.
The clearance on the rv05 is 170mm, which is more than the ft05.
Any suggestions for an other good air cooler? It seems like the NH-D14 will fit: http://www.noctua.at/pdf/infosheets/noctua_nh_d14_datasheet_en.pdf
But I would really like the performance like the nh-d15, wich beats AIO's like the h100i. Because I want quiet and performance first in this build. I don't want flashy leds or big windows, which is why I want this case, so I don't care that the cablemanagement is avarage in this case.
