Burning an ISO larger than 4.7GB
Okay, so I have obtained Adobe CS4 Master Collection and it's something around 7GB, but I only have 4.7GB DVD-Rs. Is it possible for me to burn this without having to buy dual layer disks
just mount it.....
It's actually already installed, I need physical copies of all my files though.
nigga you screwed
I guess I'll just buy some DLs.
um, get HJSplit, google it, and you can use that to split the ISO into 2 parts, enough to fit on 2 DVD's
I have Adobe CS4 Master Collection backed up on my 8GB flash drive.
Well you can compress it with WinRAR in 100mb files and then burn them , the bad part is when you want to get the ISO again , you have to copy all the rar's and then decompress them , but it's a nice solution to save some $$ in dl disks
splitting the iso is a pain in the ass... just get the DL DVD-R discs... It will save you a lot of trouble and time.
DUAL LAYER DVD ARE YOUR BEST BET BRO SPLITTING FILES IS TIME CONSUMING AS WELL AS A RAM HOGGER
