Burning a CPU
Hi guy's, i know lots of people use programs such as prime 95 to burn in a CPU, think thats the right term. just wondering if i can render on sony vegas 12 for a few hours and that will work as nicely as it also uses 8GB+ or RAM. it'll be like killing two bird with one stone as i can get video files rendered and will do the new CPU a favor.
Thanks in advance
honestly we use things like prime 95 to see if there is a stable overclock
i agree, you know what i mean. prime 95 can also be used for CPU burn in as well as it'll hit 100% CPU usage.
if you are on haswell intel cpu dont use prime95 it'll burn out your cpu literally
I5, socket 1155, little overclocking also
if you know that vegas can get your cpu to 100% for an extended period of time then it might work, but then you will still not know if your overclock is stable unless it  crashes. (then you know it's not stable) prime95 will let you know that an error occured even if it doesnt crash your computer.
The failure rate on cpus is so low, if you got a bad one you should go buy some scratch n win tickets. If your system will render half a day id assume its stable.
Edit: Oh, its overclocked, in that case you could run prime a few hours and then render, would be a waste of rendering time if prime would have shown errors after a few mins.
very very true, cheers!
ok cheers :)
