hey guys so ive built a pc and got it all running and now for some reason its like my graphics card isnt working i get worse frames per second than i had before. so here is my build if anyone has any clues on whats wrong please let me know id greatly appreciate it.
for my processor is got an intel core i7-4790 mother board is z97s SLI krait edition i am using the gigabyte geforce gtx 980 4gb gddr5 4 kingston hyper x fury 8 gb 1866 mhz ddr3 corsiar hydro series h100i gtx high performance liquid cpu cooler corsair hx750i 750 watt fully modular power supply samsung 850 evo 5000gb ssd for windows 10 2 western digital 1 tb blue drives and case is nzxt h440
I know it sounds stupid but is your monitor plugged into your gpu and not the onboard video? Use 3dmark to benchmark it and compare it to similar systems.
Need more specifics. Perform some CPU benchmark tests, as well as GPU benchmark tests, and indicate the scores of them, or at least the relative difference compared with similar systems.
It's another obvious thing, but ensure the latest drivers are being used and installed properly, or else try another driver version.
