Buildning a budget gamning pc mainly for LOL
Hi,
I want to build a gamning pc mainly for playing LOL. My budget is 450$ and I have found some parts, but my big question is about the APU / ram speed and Mobo. I would love to be able to add a GPU with X-fire and maby OC in the future.
I have found:
Case: Fractal Design Core 1000
APU: A10-5800K 4MB (PIB)
MOBO: ASUS F2A55-M / ASUS F2A55-M / ASRock FM2A75 Pro4-M
Ram: Kingston HyperX Predator 4 x 2 GB
SPU: Corsair VS450
And I all ready have an 2.5" OZ agility 240 GB ssd, a 2.5" HDD and a win8 licens.
Here are the things in which i am really in doubt:
- So the ram speed is 2400 MHz and is chosen because I heard that it increased the APU performens. But can the A10-5800K work with these or are they too fast?
- Which of the Mobo's would you recomend for me? The Oz Agility says "SATA III" on the back - how inporten is this?
- Can you recomend an ohter part for my build? My budget 450$ (I live in Denmark, so prices are a littel different, and inporting is hard from an none-EU contrey.)
- What tool do you use for calculation the watt need by the build.
- Lastly what are your thoughts on BT og WIFI - should i get a usb-dongel or?.
Let me know if i missed something importen.
Regards Jesper
- Yes, faster memory will help the 5800k a lot.  Check your motherboard to see RAM support.
- Most modern motherboards will have at least one SATA III port.  Plug your SSD into any SATA III port, and if you have hard drives, you can plug those into SATA II relatively easily.  Reference your motherboard manual to determine which connections are SATA II or III.  SATA II will bottleneck the SSD, SATA III will not.
- Looks good, perhaps a better motherboard with an A75 or better chipset would better.  MSI A75ma-E35 is a decent budget motherboard.
- pcpartpicker.com.  Use the dropdown menu on the top left to select country/currency.
- I prefer PCIe x1.  I've used USB 2.0 ones and they've worked fine.  Just make sure you don't get a really cheap and crappy one, especially if you're gaming.  Ethernet is always a better solution to wireless, though.
Hi Some tech Noob, thx for your reply i'll have a look at it :)
