Building PC for office
Hello forum!
I need to quickly build PC for office work
It needs to be stable, fast and able to do lots of multitasking. NO overclocking needed.
Also running ADOBE Illustrator and Photoshop.
Usually there will be open 10 excel and 10 word documents + Google chrome with 20+ tabs and Some work going on in Ilustrator and photoshop!
I would pretfere Intel procesor, but maybe you can convince me over to AMD.
For now I have picked these things -->http://www.dateks.lv/en/grozs?content=q1ZKL8qvKlayqlayMDEwNwIxirMTM0uAQoa1OkoWBiamGIJmBhZGJpgqLcwwBM2NLU0wVRpZmBmiCtbWAgA%3D
Here is link in other shop --> https://www.1a.lv/order/shopping_cart?content=HcrJEQAgCASwltxjBLT%2FvkRe%2BQSV4YNLyutrjJEi2vSW2iLnPQ%3D%3D
I have mice and keybord and old HDD for files.
And I think, that Old case also will be ok   In old case there was Asus M2A-VM motherboard --> http://www.asus.com/Motherboards/M2AVM/#specifications
And max height for CPU cooler is 14CM from motherboard. Here you can see OLD case pictures --> https://picasaweb.google.com/106719155637359089515/PCCase?authkey=Gv1sRgCMGpqcGEofymygE
I know 400w mabe is overkill, but it is 80+Gold and will last for ewer, because I have already changed 3 sheep PSU in last ear so I hope thiss will be good!
P.S. Maybe I have forgot something, so let me know! But the price point is 500-550 mabe if you can convince me then 600 USD
Peace to all!
And thanks in advance!
Here´s what you should do instead:
http://pcpartpicker.com/user/oscisw888/saved/3upR
Reasons:
1. Low end i5:s suck
2. B85 chipset is plenty good for officework (and it´s cheaper).
3. You don´t need aftermarket CPU-Cooling if you´re not overclocking
4. Nothing else says reliability on a PSU like Corsair
And the other stuff was almost the stuff you had, just that i didn´t care searching it up.
Ehh, I cannot open link:
It says
pcpartpicker.com$ open "/user/oscisw888/saved/3upR"
open: /user/oscisw888/saved/3upR: no such file or directory
pcpartpicker.com$
Based on what you were saying I changed things!
http://www.dateks.lv/en/grozs?content=q1ZKL8qvKlayqlayMLEwMAYxirMTM0uAQoa1OkoWBqbGlhiCJgbmRuiC5pYWlubogmbmZgYWqIK1tQA%3D
Diferent Motherboard and more expensive I5 + corsair PSU
How it is now?
MSI 760GM with a 8 core 125w cpu? realy?
And an awesome nonexistant NZXT Source 120
I found the link: http://pcpartpicker.com/user/oscisw888/saved/3upS
Just make sure that motherboard will fit inside of your case.
