Building Out A Server/NAS With Unraid - Need Suggestions
Hello,
I am looking to build out a server/nas setup and am in need of some advice after doing some research.
A little about me:
I have an IT background and am able to follow technical instruction. With that being said I am a novice to Linux and the storage side of hardware, so please be patient with me.
What i’m trying to accomplish:
I want to build out a server (either purchase from ebay, or build out with components) that uses a NetApp Disk Shelf. I’m thinking of installing Unraid on the server to allow for VM’s, Dockers, and of course NAS storage.
Things that are important to me:
  • High Core Count (For many VM’s)
  • High amounts of RAM (For many VM’s)
  • 24x Disk Shelf
  • Server have support for LSI card/s
Things i’m unsure of:
  • What drives to use (Thinking of going with 10TB drives and slowly populating the disk shelf over time.)
  • 5400 or 7200 RPM?
  • What LSI card to get? Is only one needed for all 24 bays?
  • What Raid protocol to use? (Most VM system volumes to be stored on SSD and not the NAS)
Rough Idea of what i’m going for:
  • Server - Dell PowerEdge R815, 4x16 Core, 512GB RAM, H700 (Sorry not allowed to post links.)
  • Disk Shelf - 24 tray disk shelf.
  • Drives - Seagate IronWolf ST10000VN0008 10TB 7200 RPM 256MB Cache SATA 6.0Gb/s 3.5" Hard Drives - OEM
  • LSI Card - Unknown
  • Cables - Unknown
Any help, insight, advise, education, constructive criticism, would be much appreciated.
Thanks!
It’ll be software raid, nothing in bios or raidcard firmware
Which one will be entirely dependant on how many drives of redundancy you want. Each drive of redundancy you get you lose in total usable capacity
Also obligatory “raid is not a backup”
Ahh, i’m assuming your talking about defining this in Unraid? I’m used to having to define the raid via hardware… Thanks for the clarification.
Absolutely, the plan is to have an offsite backup of with a friend.
That’s about all I got for info, I use freenas in a rosewill 4u rack case with a hand-me-down fx6300
For freenas cpu power isn’t too important if you aren’t encrypting or using disk compression
But regardless of what you do having lots of ram is.
I’d assume most of this is true with unraid as well
Let me ask the standard opening questions:
  • Whst is your budget?
  • What are your workloads (“VMs” could run a range of loads so it would help to understand if you plan to mine cryptocurrency or just host a fan site for ASCII art.
  • are you paying your own power bill?
On your specific points:
Depending on your data model and loads this may work, or be an exercise in frustration. It would help to know how much data you have total and anticipated growth.
  • By data model I mean do you want one big pool or separate pools. If separate you can add storage in phases and leapfrog existing data sets or shuffle disks as capacity per dollar prices drop in future years. For example I used to run 2TiB drives in RaidZ1. When that got full I created a new pool with 4TiB drives and the old pool became my CCTV drive, which used to be on a single disk.
  • The modern rule of thumb is to calculate enough storage for all your current data and triple it, with 1/3rd for resilience. If you buy that up front you won’t need to add storage quickly. Easier than expanding pools later.
  • if you go down zfs on Unraid or even unraids own parity you will need to add storage in blocks to benefit from resilience. It may be easier to buy in blocks of 3 disks to maintain 1 disk parity. That may adjust your disk choice. (Note You can add one disk at a time to Unraid and it magically does parity rebalancing, but all the disks need to be the same size, which limits long term scaling).
I use 5400rpm because I like staying married. 7200 is louder, especially Seagate for some reason. Also depends on your LAN. If you only have gigabit then you will max out a 5400 drive. If you want faster you will need to go 10GbE. Even then I get ~350MBps with my array of 5400 drives. So it depends if you need more than that for home use. See note below on 24 bays but if you are going more than 8 disks you need to consider enterprise drives, which will add cost.
Your VMs may be better on SSDs.
I need to ask but why do you want 24 hard drives? That is a lot of disks and you will need enterprise grade drives due to the vibrations of all 24 disks. If your data growth is modest you may be better buying fewer larger disks now and when they get full later swapping them for larger disks at better prices. Growth of storage capacity to price ratio over time is fairly linear (ie a drive that costs $25 per TiB today will cost $20 in 3 years). SSD price drops are even more dramatic.
To answer your specific question you only need one card usually with 2 ports that will connect to a SAS expander on the netapp. Some models have two dual port versions that allow load balancing or high availability.
Covered elsewhere but the disks themselves should be JBOD. Let Unraid or ZFS deal with parity. Assume 30% of your space is needed for parity if you want high resilence, 20% if you live dangerously.
