I won't try to talk you out of a 6-core Intel then... I mean they are awesome... just seem like more of a "hey, look what I bought!" than a practical solution for the intended purpose of the computer... I used to do graphic design and my i5 did the job and then some in Photoshop, Illustrator, Dreamweaver, InDesign, Flash, and Flash Builder... It really doesn't use a lot of multi-threading... I did notice a good bit of increase when I got my GTX 780 from the CUDA acceleration...
The other mobo does support RAID, however you would need to get a RAID controller, that's true...
However, I'm not sure what you'd want to expand on with the PCIe slots... once you have 2 780s in SLI, there's little need for a third... and nothing else I'm aware of really needs a PCIe 3.0 slot... however, like I said, if you want the six-core and x79 chipset, I'm not going to talk you out of it... do note the $4,000 Mac Pro has crossfired Firepro D500 which looks to be between a 280X and 270X as far as stream processors and BUS... so if you were to crossfire them you're looking at 280X performance more or less in gaming... that means one GTX 780 will significantly outperform the Mac Pro's crossfired GPU setup... I guess my question would be what expandability would you be looking into?
5600RPM HDDs are slower than 7200RPM HDDs... especially when gaming... I might at least buy one Barracuda and load games and whatnot on it, then use the Caviar Greens for media storage, which doesn't need to be fast (unless copying everything over, but that's a one time wait)
As far as the SSD goes, the Samsung EVO is nice... don't get me wrong... Corsair, Samsung, and Intel make excellent SSDs... Corsair currently has the biggest BUS on their Force series, so I chose it as it will be a bit faster...
If you'll notice, the $4,000 Mac Pro even has 16GB of Memory... it also happens to be 1866 clock which is the sweet spot for clock and low CAS latency... There's a few things about adding 64GB of memory if you aren't using it (and you won't in the next 5-6 years). First, it adds 4 more failure points to your system... Second, it will stress the motherboard powering all of them (especially at high density and clock speeds)... Third, the only reason you would ever use it is if you had a 4-6 monitor setup and ran virtual OS on each different monitor... then video edited while all that was running... Fourth... RAM is by far the easiest upgrade to install on a computer... pull two tabs, push... done... if you need more later, buy more...
As far as who makes good memory... I always look between Corsair, GSkill, Crucial, Samsung, Kingston, Adata, and Mushkin... whoever has the size/speed/lowest CAS/price combination I'm looking for, I'll recommend, all are quality...
About the case... if you like the Fractal case better than the Corsair (which is also a nice case) EATX isn't supported by the Define R4... the full tower version is the Define XL R2 but I don't think it comes with a window (and if you spend $4,000 on hardware I'm pretty sure you'll want to look at it) the XL R2 is a bit cheaper, however, and Fractal's cases are extremely high quality and designed very well...
If you're looking for air coolers, there's a few options... I'm a fan of Cooler Master Hyper EVO for budget, Enermax ETS-T40, any Phanteks model (depends on what size), and any Noctua model (again, depending how big you wanna get)
I don't mind overkill, but I encouriage you to not just throw gobs of money at a computer without any particular reason for it... key things to look at:
4-core Haswell i7 vs 6-core Ivy Bridge E i7
Water or Air cooled?
If you go with the Haswell i7/Z87, what expandability are you really missing out on? (also dictates case choice)
How much memory do you REALLY need? Are you running virtual OS or video processing? If no, 16GB is plenty of overkill...
How big of an SSD are you comfortable with? What programs/OS do you want on it? Get big enough to hold your core programs and operating system, maybe a little to play with, and that's all you need...
I encourage you to try ONE 780 out before you introduce SLI... they are monsters...
A lot of these decisions are based off the processor/mobo choice... but if you're multitasking/photo editing/gaming/media serving.... you aren't doing anything that needs a $4,000 system... I'm not saying don't do it... just be aware you're buying more than you'll ever use with the $2,000 build I posted (maybe you really do need that much storage, I haven't seen your media collection haha)...
I do think either build will last 5-6 years easily... hope I helped...
