Which slot is the GPU in? I would start with the top slot, then move to the second to see if the slot is faulty.
Never mind, I have it working now!
In regards to the 1080, I want this machine more for productivity than gaming right now. I will happily upgrade the graphics card at a later date and put the 1070 ti in my wife’s (my old) computer.
Thank you all very much for your time and help. <3
What was the cause? Also, some boards take a long time on first boot, although I didn’t notice that with my Prime X370 Pro.
It was the dumbest thing, but also the easiest to fix thing: The HDMI cable needed a bit more of a push into the socket.
It boots instantly and the system looks very nice too. (IMO)
For my first self-built I am quite happy with the cable management too.
Can we get a shot of the internals?
Report because you forgot NSFW tag
Nice and clean setup.
cool
Let the unicorns begin to puke!
Nicely done, have fun with your system.
My CPU has been running over 60C at idle, so I wanted to check what was going on. My CPU has fused to the heatsink. Should I do the soak in rubbing alcohol solution?
Also one of the pins is bent now. When I removed the heatsink the CPU just up and came with it.
Edit: Never mind, I’ve removed it and straightened the pin.
save $100, download linux
CPU is back in with new thermal paste etc. Still running over 60C at idle. This can’t be right…
Edit: Just downloaded Ryzen Master which is telling me at idle I am at around 50C. CAM is still reporting 60 to 70 lol. Think I’ll get rid of CAM.
When using something like HWinfo, look at CPU (Tdie)
Example:
How is the ram working for you? Any issues? Is it running at 3200?
Average Temp is 43C at idle.
Using HWInfo my memory Clock is at 1,596 MHz
I set it to 3200 in BIOS…
Edit: I feel like I just forgot the D in DDR.
That is 3200MHz. It’s DDR (double data rate).
Good to know. Doesn’t seem clear what exactly should and shouldn’t work.
43°C idle depending on fan settings and cooler seems reasonable.
