Building My First Rig,need opinions
Now I'm building my first gaming rig/light work station for photoshop,and some video editting.
Specs are down below :
CPU : Intel Core i5-3570K
CPU Cooler : CM Hyper 212 Evo
Mobo : Gigabyte GA-Z77X-UD3H
SSD..suggestion? 120GB is enough for me. I don't need the fastest,just a budget friendly and most important thing,lifespan.
HDD : Seagate Barracuda 2TB 7200RPM
Optical : Asus 24x DVD Burner (Don't judge...I still need it for some reason..)
Case...I prefer Thermaltake Commander MS-I..it's budget friendly and look quite nice..suggestion are appreciated though.
GPU...the most important thing...I chose the HD 7870...but the 7970 and the 660 ti looks quite promising..need suggestion here.
I need suggestion to make it better..so pls help,I'm new here :)
My Budget is below $1000. a few bucks higher than my budget should be fine.
Thank You.
And Just for fun,my current pc lol
Intel Atom 330 @ 1.6GHz Dual core with HT
Intel GMA 950 (LOL)
500Gb Seagate Barracuda (I only know it's from seagate,but not sure if it's a barracuda)
http://pcpartpicker.com/p/szH0
I tried to keep as much of the original parts that you suggested, however a few sacrifices needed to be made in order to bring it below budget. As it stands with prices at the time of this post it would be 991.88 after rebates and 1011.88 without them.
It ended up being a fairly cookie cutter build but i somehow managed to actually get a color scheme going with everything.
Edit: Forgot to touch on a few points.
For the budget a 7870 is a prime choice, Compairing the performance to a 660ti they are neck and neck is some cases and you can easily overclock the 7870 at that price point it is a fantastic card to go with.
For the SSD i have found 120gb an ideal number when just using it as a boot OS and having a few applications installed. There is a very good SSD optimization guide over a Overclock.net http://www.overclock.net/t/1156654/seans-windows-7-install-optimization-guide-for-ssds-hdds
It gives a good first steps to make sure the SSD is performing as it should and it helps to free up some space on it with some of the steps.
Sticking with 8gigs of ram for now but that leaves you with 2 slots unpopulated leaving you room for expansion in the future as well as an Crossfire ready board incase you wanted to go that route.
If you want to take an amd route it may be cheaper.
6 core-
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1239961&CatId=7341
Mobo-
http://www.tigerdirect.com/applications/searchtools/item_upsell.asp?EdpNo=2713117&msg=
GTX 570------BEAUTIFUL CARD-Friend has one.. blows the crap out of my brothers 560ti
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=426309&CatId=3669
 everything else seems good :)
Even in this case i would still recommend the 7870. The Gigabyte version i had in my post was basically the same price and it seems to beat out the 570 in a few benchmarks.
http://www.anandtech.com/bench/Product/518?vs=548
As well as the 225 price point on tiger being after a rebate.
I wouldn't drop that cpu since it's going to last you for at least 3 years. For an SSD get a 240 crucial M4 or an 240 intel 330, i thinkt he m4 will be the cheaper of the two, also check out the OCZ vertex 4 there's a bunch of places trying to liquidate it.
Cases:
Cooler Master
Antec
Zalman
Bitfenix
Silverstone
I'm loathe to recommend a thermaltake anything, roll with any of these. The shinobi and the antec are the best ones imo.
I'm not sure what the SSD will do to your budget but if you're buying cards here's the progression in terms of price/performance:
7870, 660ti, 7950boost,7970ghz, 680.
Thanks,I'll go with the 7870 then :)
What's the difference between the Asus P8Z77-V LK and GA-Z77X-D3H?
So...which SSD should I get?
I don't like the amd processor. (no offense,I'm not a fan of intel also,I just prefer for using intel)
Wow...570....I'll think about it
Thanks for you help :)
If you're looking for a budget SSD, Samsung 830 or OCZ Vertex 4
If you want performance SSD, Samsung 840 Pro or OCZ Vector.
Obviously chose whatever size fits your needs.
As for case, I like the Antec P280 and Fractal Design R4.  But both are near or at the $100 mark.  The Antec p280 usually goes on sale for like $80-90.  If that is too expensive then I guess an Antec Three Hundred Two or Bitfenix Shinobi could fit the bill.
If you can make use of the AMD game promo then try to fit the 7950 in your budget.  If not, 7850 is fine and you still get one game anyway!
Ok guys,sorry but I forgot to mention that I will use this rig in triple 1080p monitor and I'll be soon making a youtube channel for gaming walkthrough.
And BTW, 7950 and 660 ti cost about the same in my country.
Either is the GTX 660 ti is too expensive here or 7950 is cheaper here. (lol)
I heard that Maxwell GPU,and new 8000 series GPU is coming next year..should I wait?
No, because next year you are gonna hear that the whoknows gpu comes out so you will wait another year and so on.
if that made any sense.
But the 3GB VRAM is important...especially in a game like max payne 3...triple monitor uses just over 2GB VRAM. 2GB is not enough.
VRAAAAAM...tasty lol
it actually make sense...
Multi-monitor gaming requires lots of vram for sure.  7950 is a no brainer over the 660 Ti.
660 ti has a 3GB version..I think.
