Building my first pc! Tell me how this sounds
I have added a star next to parts I already have.
Case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811119240 *
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157293
Processor: http://www.newegg.com/Product/Product.aspx?Item=N82E16819115233
Graphics card: http://www.newegg.com/Product/Product.aspx?Item=N82E16814150617
HDD: Some 644 GB I had lying around, works fine *
Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231460
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817139021
Also, If I end up with enough money, I will be getting this ssd
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148441
not sure if I'll end up with the money for that, but if so would it be a good one?
Any modifications? Please keep it around 500-550
I'm slightly confused. I used a good portion of what you did, just trimmed some things you wouldnt really need, but it came to higher then what you wanted to pay... but its less then your things.
http://pcpartpicker.com/p/sp6Y
My apologies, messed up when listing my price range, thanks for the reply. I'll wait till around christmas to order, seeing as how there will probably be a bunch of sales around then.
http://pcpartpicker.com/p/spmt I think you miss typed you said $500-$550 i think you ment 7-750 if so then this : http://pcpartpicker.com/p/spph
Already have a case, so I can count that as 50-60 dollars cheaper.
Looks very nice, I think it may be worth it to wait to buy this for the 7950, Depending on what sales are around after xmas.
you can get a 7970 for a little more so if we drop the cass and go with the 7970 we get $747 after rebates http://pcpartpicker.com/p/spxH
http://pcpartpicker.com/p/sz6N, just saved a bit more money (like 3 dollars) and got a more reliable PSU from a better supplier.
