Hello
I am new to building a PC, so I tried to research a lot and find as much information as I could get. It seems my need of this machine made this game much harder, as everything seems more complicated with servers. And to make it harder, everything is much more expensive, so there’s no place for mistakes.
That is why I am here asking you to please review my situation and, if possible, answer my questions.
I read a lot here, and much of my knowledge is from here, so thank you.
Okay, now what I want to make:
It will be my everyday home workstation, used for database and AI. I will need a powerful CPU, fast disks, and a lot of RAM. It will be near my desk. Noise level is important, but not if it limits the system’s abilities.
Here is the machine at this point:
Motherboard: Gigabyte MZ73-LM0
CPU: AMD 9355 (2X)
Cooler: Arctic Freezer 4U-SP5 or Silverstone XE04-SP5 (2X)
RAM: DDR5 RDIMM 64GB (24X)
PSU: Seasonic PRIME TX‑1600 ATX 3.1
GPU: NVIDIA GeForce RTX 4090
USB: ASUS USB4 PCIe Gen4
M.2: ASUS Hyper M.2 x16 Gen5 Card (2X)
NVMe: Samsung SSD 9100 PRO 2TB (5X)
HDD: Seagate HDD 3.5 8TB
Case: Thermaltake Core P3 or SilverStone RM51
And here are my questions or doubts. I know some may sound clear or silly, but I will be grateful if you can comment about any of them
- Q1: I want to first verify and test the system with 1 CPU, 2 RAM, and 1 NVMe. Is it possible to run this system with 1 CPU? All my research leads to yes, but I want to be absolutely sure that this motherboard and CPU allow this.
- Q2: Gigabyte MZ73-LM0 is the most “normal” motherboard I could find that supports 24 DIMMs. Is there any better option? I ask because I saw a lot of posts about not posting and issues with BIOS, etc.
- Q3: I could only find these two coolers verified for this CPU and from a legit brand. Which cooler is the better option? Arctic Freezer 4U-SP5 or Silverstone XE04-SP5? I read good (powerful and good price) and bad things (unreliability) about Arctic, but it seems more powerful (81 CFM compared to 77 CFM) and almost similar max noise levels (45 dBA vs 43 dBA). Is there any option that I should take note of?
- Q4: I read about changing cooler fans with Noctua or Sanyo Denki 140mm 9RA. But I doubt that this is possible for Arctic. Can I customize the cooler for lower noise? Should I?
- Q5: I saw and read about the importance of pressure on the cooler and CPU. But it seems the Arctic one comes with a simple screwdriver. Should I get a torque screwdriver for this use?
- Q6: I read that in this case of having 24 DIMMs on 12 channels, the speed will be limited. Documentation of the motherboard says that for this CPU it can support up to 6400 MT/s, but AI tools say that it will clock down to 5600 MT/s. Is it correct? And why? Should I get 5600 or 6400?
- Q7: The motherboard QVL says I should get the RAM from Samsung, Kingston, Micron, or SKhynix. I do not know which is better, and it seems only Micron and Samsung are the creators of the chips, and Kingston only makes the sticks, right? Is there any difference between these ones?
- Q8: It seems this motherboard needs a battery, but I saw a video that said it does not have one and did not mention what type of battery will be needed.
- Q9: From calculation of the power usage and keeping headroom for the future, I chose the PSU, but if you think it can be limiting or overkill, please do tell. Is it a good choice? It seems big too and limits the case options.
- Q10: Does this PSU have enough cables for these devices? It seems enough, but reading about ATX 3.1 and different kinds of cables, I am not sure.
- Q11: This motherboard has limited USB support, so I added the USB card. I need it to be fast, but if there is a better option, please share.
- Q12: This machine will need to be used for a lot of file reading (mostly sequential), so I am thinking about RAID 0ing the NVMe. From what I gather, it seems I need to give each CPU something to work with, so I need to add one M.2 card (each with 2 NVMes) to each CPU PCIe to get the maximum speed. Is my assumption right? Another NVMe will be added directly to the board for the OS.
- Q13: I like the Thermaltake Core P3 case, and I read here (The Zen of Air Cooling) that it is possible, but the case documentation does not show EATX support. As @JayVenturi seems a professional, maybe he changed the case. If it is not possible, I like the SilverStone RM51, and it seems I can remove the 3.5 slot to make space for the PSU and still have space for the one HDD I will need.
- Q14: I am a Windows 11 user, but I read that these machines are only used with Windows Server. Can I use Windows 11 Workstation? Should I use it, or am I better off with Windows Server? If yes, what version is your suggestion?
Thank you.
