*Building my first Gaming PC*
  • Budget: im willing to spend $500 because i was thinking of building the $350 but i cant play the triple a game titles
  • In the future & and i will be Gaming, Rendering & home media PC "Downloading Torrents"
  • if a custom watercooling is not so much then ill plan on going for it in the future.
  • I Dont have a OS , i was thinking of getting on off torrents? idk if thatll work ?
         Gaming Info
  • i want my FPS to run just like if i was on a Ps3 or Ps4 :) lol
                    im picky about my resolution
  • I use PhotoShop and Video editing there not that heavy but After Effect.
  • Games ill be Playing MMO &FPS & triple a game titles
No way you can get a rig for $500 that will play games at 1080p and will render after effects and do video editing really well. One or the other, I can try.
Eh.  Should be decent at gaming for the price: http://pcpartpicker.com/p/2hW68
So like about how much more are we talking about to build it, i mean im just not trying to spend much, i have 700$
I can't tell you to go and pirate your OS in a torrent - but we both know that you're going to try.
$500 after mail in rebates.
http://pcpartpicker.com/p/2hWIT
Should be ok for editing and the GPU is very competitive with the PS4. It will play many games at high settings 1080p. You should add more RAM to help with editing, there is only a single stick in this build.
This is around $500 after MIR:
http://pcpartpicker.com/p/2hWQ2
This will play 9/10 games on ultra settings at 1080p. If you need it lower than $500 I would suggest using this build and the cheaper 7850.
Just some ideas. if you have $700 you can tidy up these builds or go for higher performing parts.
