Building my first gaming PC. Comment on my build!
Hey guys, this is my first gaming PC build EVAR! I am coming from the console's and over to the PC master race(Not completely, though ^^). I have chosen all of the parts for my build, and I was wondering if you guys could give me some feedback and other reccomendations if needed.
Here we go!
Intel Core i5-2500k Sandy Bridge
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115072
MSI GeForce GTX 660 Twin Frozr
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4805060&csid=_61
Antec Three Hundred Black Steel
http://www.newegg.com/Product/Product.aspx?Item=N82E16811129042
ASUS P8Z77-V Intel 7 Series Mobo
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2406888&Sku=A455-2042
Seagate Barracuda 7200rpm 500GB SATA3 HDD
http://us.ncix.com/products/?sku=63468&vpn=ST500DM002&manufacture=Seagate&promoid=1387
G.SKILL Ripjaws Series 8GB RAM
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231314
Samsung 830 Series 128GB SSD
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2318704&csid=_61
Thermaltake Toughpower XT 575w power supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817153125
Thats it guys! Comment on my choice of parts if you like! If you want, you can also suggest better parts, or suggest different websites to buy from to get better deals. Thanks!
We don't use that term 'round these parts.. them tiger lillies can go fuck themselves.
try getting a case with cable management options it will help you with air flow & less headache & if your gonna be overclocking my a suggest this
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103099 works wonders for my CPU plays crysis 2 on max not getting over 40c
Alright, I will add that to my list.
