hi all,
ive been trying to build a new Budget gaming rig and need your opinions before im gonna try to build it
i wanted a rig that could play The Division on about med to high settings
price point is around 500 euros and with this im already over budget. anyway this is what i picked:
Case: Bitfenix Comrade
CPU: AMD FX 6300 3,5GHz black edition
MOBO: Asus M5A78L-M LX3
RAM: Crucial ballistix sport XT 8gb ddr3 1600mhz
HD: WesternDigitale Blue 500gb
PSU: EVGA 500B Bronze 500w
GPU: Sapphire Dual-X R9 270 OC 2gb gddr5
Personally i was thinking of using the Asus M5A78L-M/USB3 MOBO zo i could upgrade my CPU to a AMD FX 8350 at a later stage if needed. as for the harddisk i probably plan on buying another one of 500gb and an ssd at some point together with a better CPU fan later on.
but let me know what you think
