Building first PC
So, basically, I would like to build a gaming PC for around $1,000. I have been scouring the internet for some time now, and never found anything solid. I am completely new at this, and therefore have no idea what I am doing. If you could help me out, that would be great!
here this is what i tried setting up for you, when your getting and os (operating system) get a windows 7 professional oem 64 bit. oem just means one disk and you can make a clean start without un needed softrware. just look it up on newegg build your pc part 3. it explains it
http://pcpartpicker.com/p/1ph3S
you will also want a networking card or a usb wifi adapter, and unless you have a dvi cable for your tv ur gonna want a monitor... i hoped i helped
here is a quick build
