Building First PC
Hey I'm from Australia and I am interested in building a PC.  it will be my first build and I'm wanting to use it for gaming mainly with the occasional editing.
Here is the parts i was thinking of using:
I was wondering if they would all be compatible or is there anything else i would need.  Also are there any cheaper options that would do the same job>
That's a nice build for what you say you want, everything is compatible. I would suggest spending another $4 on the 1.5v version of the that ram though. Its generally more compatible with motherboards and well it uses less power which is always good.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=186_538_913&products_id=18373
I would aso suggest getting the Antec One case, which is an extra $4, mainly because it has usb3 front panel ports and the one hundred doesn't. Considering you have picked a motherboard with usb3 I think its a better way to go.
http://www.pccasegear.com/index.php?main_page=product_info&cPath=25_547&products_id=19320
Depending on what your budget will allow for, I'd also have a look at the seagate barracuda 2tb which is an extra $25 but is double the capacity. I'm currently running that drive in my rig now.
The PCS+ version of that powercolor graphics card has a clock speed of 1100mhz which is 100mhz faster than the one you've picked for an extra $10, although you probably wouldn't notice the difference.
These last two are up to you, if you don't want to spend the extra cash you won't be missing out.
