i am not sure if this PC build is good or not. I just sort of through some things together. here's the list, tell me what you think. http://pcpartpicker.com/p/2vIWp
p.s. i will be mainly playing dayz and arma on this computer. thanks for any help i get. :)
If you plan to upgrade to 16GB in the coming weeks or months, stick with the 1x8GB of RAM. Otherwise, I suggest running dual channel RAM(2x4GB).
You don't need that fancy or that strong of a PSU. 500W is plenty for this system.
R9 270s have pretty much the same performance as 270Xs, at a lower cost.
840 Pro is expensive in this budget. I would suggest a budget SSD(still will be pretty damn fast), and a normal HDD.
Full tower is BIG. BIG. Most computers a Micro ATX or Mid Tower. I find Mid tower pretty big already. I switched it out for a very quiet, high quality Mid tower case.
CX600M is the same price as the CX500M. Semi-modularity will help with wiring your first build as well.
Might as well help ya out a bit:
http://pcpartpicker.com/p/2vTZL
Well, it's over $100 less than your build, so let's see what we can improve.
http://pcpartpicker.com/p/2vU8p
6 core CPU, with a nice motherboard that can allow upgrades to an 8 core CPU.
Nice motherboard also allows for crossfire/SLI
Much stronger GPU
thanks a lot for he help. the build i had isnt even started. i don't have the parts yet because i have really no idea what im doing. thanks a lot for the help though, i'll be sure to check out the links you put in.
There are some major imbalances in your cost allocation, IMO. You can get FAR far better performance at that price point. But before anyone makes any new suggestions, there are some key things we need to know first;
-What is your total budget? (with or without OS?)
-What is the primary use? Gaming?
-Are you dead-set on that PC case? Only reason I ask this is because you can get some very good cases for much less.
For a gaming PC in the $850-900 range, you could build something like this; http://pcpartpicker.com/p/2vUqP
*edit* Looks like I took too long to post...lol.
no you didnt i will take all the help i can get. im open to anything. my budget is around $600-700 if i can. as for the case. i do like it. im a case guy for sure but id change anything on this build because as ive said i have no clue what im doing which is why i came here.
edit- my primary use is gaming. mostly dayz/arma.VERYdemanding game
Here's my revised suggestion for $700 budget. http://pcpartpicker.com/p/2vVPN
Removed the CPU cooler (can always add one later), removed the SSD (again can be a future upgrade) and swapped out the 7950 (which would be hard to find anyways) for an R9-270X. This will play Arma/Dayz no problem. I prefer AMD GPU's but if you can find a good deal on a GTX 760 for close to $200, that would be a good choice as well.
If you really want the SSD you could go with an FX-6300 CPU instead and use the extra ~$40-50 towards the SSD. Would put you a little over budget though.
+1.
Thanks a lot for all your help MEC-777 and Some Tech Noob. you've helped out a computer noob greatly XD if anyone else is reading this forum im still open and always will be open to ideas i have $200 so far for this build so it's gunna be a while before i start buying parts.
No prob. Happy to help in any way we can. It's what this forum is here for. ;)
Depending on how long it takes you to save up the rest, there may be other parts available at that point that offer better value. So don't write your current build list in stone. Technology changes rapidly.
When I did my latest build (Sept 2013), my entire parts list changed completely over the course of the few months leading up to the actual build. When you have the cash in hand and you're ready to go buy everything, post up again and we'll help you come up with another list. :)
alright will do. ill post it on this same forum. btw heres the final list for now. i kept the other case and added an optical drive for os. also not sure if i should or need to get a sound card. what do you guys think? http://pcpartpicker.com/p/2wb1U
If you plan to upgrade to 2 GPUs, I'd suggest getting the Asus M5A99FX Pro R2.0
Otherwise, everything looks good.
i dont really plan on it. im new so im trying to stay pretty simple until i know what im doing. thanks though
The mb they had selected supports SLI and crossfire as well. ;)
If you don't want or need the optical drive, you can install the OS via USB stick. ;)
oh alright. do i need a sound card though?
Nope.
Onboard is pretty damn good for 99% of people. Unless you're an audiophile you probably won't even hear the difference.
alright thanks
wait how would you get a new os on a flash drive? it comes on a disk...
