Building first Budget PC
Hello, I am looking at building a budget pc of £300 to £350.
To be able to run games and be fairly small but also I need it to be wireless as out in a static caravan.
Also I would like it to be able to upgradeable in the future, late the end of the year when prices drop for that short period.
Any ideas would be much appreciated thank you.
This is the closest I was able to get before it wouldn't really be worth it. It's quite a bit over the £350 mark, but I'm not sure if I could make it much cheaper.
http://uk.pcpartpicker.com/p/341QC
You could save some money by buying used though, and you might even be able to find somebody's old rig that would be a little faster for around the same price too.
Thank you, i'll bookmark that one =-]
This extra little bit would do you a lot better.
http://uk.pcpartpicker.com/p/342gz
Here's an AMD build.  I find that two cores isnt cutting it for gaming anymore.
http://uk.pcpartpicker.com/p/3437A
+1
I was going to go AMD, but I misread OP as really small rather than fairly small. Don't forget to add a wireless adapter!
Whaoo those are all really good builds =-]
Here are three build I came up with from them ?
AMD APU =
http://uk.pcpartpicker.com/user/RagingChaos/saved/3Whc
AMD 4 Core =
http://uk.pcpartpicker.com/user/RagingChaos/saved/3Ggw
Intel Mini ITX =
http://uk.pcpartpicker.com/user/RagingChaos/saved/3WWS
The Sapphire Card is the "Sapphire Radeon HD 7770 Vapor-X GHz Edition Video Card" for £83.50
AMD FX Build =
http://uk.pcpartpicker.com/user/RagingChaos/saved/3JEW
