Building Editing PC(tips)
Hi, I'm building an editing pc for After effects, but also some mild to light gaming. Any suggestion would be helpful, I have already purchased the CPU and case, so they are not changeable
http://pcpartpicker.com/user/ctshaw96/saved/2OKa
This GPU will be a better value: http://pcpartpicker.com/part/pny-video-card-vcggtx7702xpb
I don't know why you need so many fans, as well.
Otherwise it looks good.
Thanks, and I have alot of fans so I can run all of them but on slower speeds to keep noise low
