Great stuff!!
Hey, Iām trying to build zfs builtin kernel in CentOS. Should I be seeing the usual zfs.ko spl.ko, etc. files in /usr/lib/modules? With dkms, theyāre usually in extra, and kmod theyāre in fs/zfs. I havenāt seen them anywhere in any of the builtin kernels Iāve compiled, and sometimes when I see the make process have an error itās got a gpl-compatibility error that stops the process.
Thereās multiple ways for module code to work:
- Built-in
- Using initramfs (linked as a blob in the same file)
- Using initramfs in initrd
- Loaded from /lib/modules/ā¦
The bottom 3 will have .o files linked into .ko files and stored on the filesystem for dynamic linking and loading at some point in the boot process, or perhaps at leisure.
The first one will see the .o file linked alongside other .o files (like the scheduler, the networking, the process and memory management code) into the same binary blob/executable.
Itās strange youāre getting the āGPL compatibility errorsā as an end user youāre allowed to link code together between GPL and CDDL (or even with proprietary code), as long as you donāt intend to publish it linked together online.
If I install the headers and devel packages, in /usr/src/kernels I appear to have good signs
My Module.symvers
has this:
$ grep zfs Module.symvers
0x00000000 zfs_set_userquota vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_multilist__remove vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_visible vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zfs__rrwfastpath__exitmiss vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_to_name vmlinux EXPORT_SYMBOL
0x00000000 zfs_sa_set_xattr vmlinux EXPORT_SYMBOL
0x00000000 zfs_sa_get_xattr vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_arc__evict vmlinux EXPORT_SYMBOL
0x00000000 zfs_set_version vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zio__delay__skip vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_l2arc__iodone vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_default_string vmlinux EXPORT_SYMBOL
0x00000000 zfs_close vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_remove__free__unvisited vmlinux EXPORT_SYMBOL
0x00000000 zfs_id_overobjquota vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_free__long__range vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_multilist__insert vmlinux EXPORT_SYMBOL
0x00000000 zfs_userquota_prop_prefixes vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_valid_keylocation vmlinux EXPORT_SYMBOL
0x00000000 zfs_vget vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zio__delay__miss vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_remove__free__inflight vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_dbuf__state_change vmlinux EXPORT_SYMBOL
0x00000000 zfs_sa_set_scanstamp vmlinux EXPORT_SYMBOL
0x00000000 zfs_sa_get_scanstamp vmlinux EXPORT_SYMBOL
0x00000000 zfs_zpl_version_map vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zio__delay__hit vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_delegatable vmlinux EXPORT_SYMBOL
0x00000000 zfs_inactive vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_taskq_ent__start vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_blocked__read vmlinux EXPORT_SYMBOL
0x00000000 zfs_is_readonly vmlinux EXPORT_SYMBOL
0x00000000 zfs_special_devs vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_arc__wait__for__eviction vmlinux EXPORT_SYMBOL
0x00000000 zfs_dataset_name_hidden vmlinux EXPORT_SYMBOL
0x00000000 zfs_readlink vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_dsl_pool_sync__done vmlinux EXPORT_SYMBOL
0x00000000 zfs_write vmlinux EXPORT_SYMBOL
0x00000000 zfs_rangelock_fini vmlinux EXPORT_SYMBOL
0x00000000 zfs_symlink vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_readonly vmlinux EXPORT_SYMBOL
0x00000000 zfs_userspace_many vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zfs__ace__allows vmlinux EXPORT_SYMBOL
0x00000000 zfs_tmpfile vmlinux EXPORT_SYMBOL
0x00000000 zfs_statvfs vmlinux EXPORT_SYMBOL
0x00000000 zfs_ereport_post_checksum vmlinux EXPORT_SYMBOL
0x00000000 zfs_setsecattr vmlinux EXPORT_SYMBOL
0x00000000 zfs_getsecattr vmlinux EXPORT_SYMBOL
0x00000000 zfs_remove vmlinux EXPORT_SYMBOL
0x00000000 zfs_space vmlinux EXPORT_SYMBOL
0x00000000 zfs_zstd_decompress_level vmlinux EXPORT_SYMBOL
0x00000000 zfs_sa_readlink vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_get_table vmlinux EXPORT_SYMBOL
0x00000000 zfs_name_to_prop vmlinux EXPORT_SYMBOL
0x00000000 zfs_mkdir vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zil__process__normal__itx vmlinux EXPORT_SYMBOL
0x00000000 zfs_suspend_fs vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_encryption_key_param vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_arc__async__upgrade__sync vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_txg__opened vmlinux EXPORT_SYMBOL
0x00000000 zfs_umount vmlinux EXPORT_SYMBOL
0x00000000 zfs_userspace_one vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zil__process__commit__itx vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zfs__rrwfastpath__rdmiss vmlinux EXPORT_SYMBOL
0x00000000 zfs_getpage vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_arc__delete vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zfs__fastpath__execute__access__miss vmlinux EXPORT_SYMBOL
0x00000000 zfs_ereport_is_valid vmlinux EXPORT_SYMBOL
0x00000000 zfs_post_state_change vmlinux EXPORT_SYMBOL
0x00000000 zfs_acl_byteswap vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_l2arc__hit vmlinux EXPORT_SYMBOL
0x00000000 zfs_znode_byteswap vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_userquota vmlinux EXPORT_SYMBOL
0x00000000 zfs_map vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_dbuf__evict__one vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_txg__synced vmlinux EXPORT_SYMBOL
0x00000000 zfs_fsync vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_default_numeric vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_user vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_inheritable vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_dnode__move vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_string_to_index vmlinux EXPORT_SYMBOL
0x00000000 zfs_rangelock_reduce vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zrlock__reentry vmlinux EXPORT_SYMBOL
0x00000000 zfs_prune vmlinux EXPORT_SYMBOL
0x00000000 zfs_resume_fs vmlinux EXPORT_SYMBOL
0x00000000 zfs_obj_to_path vmlinux EXPORT_SYMBOL
0x00000000 zfs_sa_symlink vmlinux EXPORT_SYMBOL
0x00000000 zfs_create vmlinux EXPORT_SYMBOL
0x00000000 zfs_component_namecheck vmlinux EXPORT_SYMBOL
0x00000000 zfs_getattr_fast vmlinux EXPORT_SYMBOL
0x00000000 zfs_create_fs vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_written vmlinux EXPORT_SYMBOL
0x00000000 zfs_spa_version_map vmlinux EXPORT_SYMBOL
0x00000000 zfs_history_event_names vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_l2arc__read vmlinux EXPORT_SYMBOL
0x00000000 zfs_zstd_cache_reap_now vmlinux EXPORT_SYMBOL
0x00000000 zfs_id_overblockquota vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_txg__quiesced vmlinux EXPORT_SYMBOL
0x00000000 zfs_rangelock_init vmlinux EXPORT_SYMBOL
0x00000000 zfs_attr_table vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_index_to_string vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_txg__syncing vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zfs__dprintf vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_txg__quiescing vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_l2arc__miss vmlinux EXPORT_SYMBOL
0x00000000 zfs_putpage vmlinux EXPORT_SYMBOL
0x00000000 zfs_allocatable_devs vmlinux EXPORT_SYMBOL
0x00000000 zfs_deleg_canonicalize_perm vmlinux EXPORT_SYMBOL
0x00000000 zfs_deleg_whokey vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_valid_for_type vmlinux EXPORT_SYMBOL
0x00000000 zfs_deleg_verify_nvlist vmlinux EXPORT_SYMBOL
0x00000000 zfs_readdir vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_get_type vmlinux EXPORT_SYMBOL
0x00000000 zfs_oldacl_byteswap vmlinux EXPORT_SYMBOL
0x00000000 zfs_rmdir vmlinux EXPORT_SYMBOL
0x00000000 zfs_zstd_decompress vmlinux EXPORT_SYMBOL
0x00000000 zfs_link vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_arc__hit vmlinux EXPORT_SYMBOL
0x00000000 zfsvfs_create vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_setonce vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_delay__mintime vmlinux EXPORT_SYMBOL
0x00000000 zfs_lookup vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_remove__free__synced vmlinux EXPORT_SYMBOL
0x00000000 zfs_preumount vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_taskq_ent__birth vmlinux EXPORT_SYMBOL
0x00000000 zfs_post_remove vmlinux EXPORT_SYMBOL
0x00000000 zfs_id_overquota vmlinux EXPORT_SYMBOL
0x00000000 zfs_setattr vmlinux EXPORT_SYMBOL
0x00000000 zfs_ereport_post vmlinux EXPORT_SYMBOL
0x00000000 zfs_max_dataset_nesting vmlinux EXPORT_SYMBOL
0x00000000 zfs_remount vmlinux EXPORT_SYMBOL
0x00000000 zfs_fid vmlinux EXPORT_SYMBOL
0x00000000 zfsvfs_free vmlinux EXPORT_SYMBOL
0x00000000 zfs_prop_init vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_new_state__mfu vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_new_state__mru vmlinux EXPORT_SYMBOL
0x00000000 zfs_dirty_inode vmlinux EXPORT_SYMBOL
0x00000000 zfs_post_autoreplace vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_l2arc__write vmlinux EXPORT_SYMBOL
0x00000000 zfs_domount vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zfs__ace__denies vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_arc__demand__hit__predictive__prefetch vmlinux EXPORT_SYMBOL
0x00000000 zfs_zstd_compress vmlinux EXPORT_SYMBOL
0x00000000 zfs_rangelock_enter vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_taskq_ent__finish vmlinux EXPORT_SYMBOL
0x00000000 zfs_sa_upgrade_txholds vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_arc__miss vmlinux EXPORT_SYMBOL
0x00000000 zfs_read vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_zil__commit__io__error vmlinux EXPORT_SYMBOL
0x00000000 trace_zfs_l2arc__evict vmlinux EXPORT_SYMBOL
0x00000000 zfs_rename vmlinux EXPORT_SYMBOL
0x00000000 zfs_access vmlinux EXPORT_SYMBOL
0x00000000 zfs_sa_upgrade vmlinux EXPORT_SYMBOL
0x00000000 zfs_rangelock_tryenter vmlinux EXPORT_SYMBOL
0x00000000 zfs_rangelock_exit vmlinux EXPORT_SYMBOL
0x00000000 zfs_open vmlinux EXPORT_SYMBOL
and then fs/zfs
and include/zfs
folders exist. The only problem is all I see is .h and .c files, thereās no .o or .ko files at all.
I guess Iāll try this out and see what happensā¦
oh wow, I tried building a kernel in Ubuntu in a chroot environment, and all of the sudden thereās all these .o
files being built after a basic make
Iām not sure whatās going on with my rhel
environment, but apparently it is not conducive to building kernels. Something is wrong.
Update: Nevermind, I guess I just wasnāt searching for them properly. I see the zfs .o
files, but the kernel builtin rpms still arenāt working.
Whatās more, rhel /usr/src/kernel/ doesnāt have any .o
files, while the Ubuntu src folder has all of the ones I would expect.
lol I went back to Ubuntu this afternoon and have built 3 zfs-builtin kernels already. Way too much fun. So much easier on Ubuntu.
