This is my list so far, I am just looking for suggestions, I am building a personal rig because I am selling the one I am using (4670k and GTX 770 there is nothing wrong with it, a buddy just needed an upgrade). There is no GPU on the list yet because I am waiting for any pricing on the 290x and all that jazz. I don't know much about the Prodigy M and I haven't done much research, I just mainly want to know if it will all fit and if there are better options than what I have chosen up there. Thanks ahead of time!
for the prodigy m you are going to want a single rad cooler like the h80i or an air cooler like the phanteks tc14pe. Other then that I would recommend a z87 motherboard and if you go air cooling some lower profile memory like the vengeance lp
awesome, thanks for the suggestions.
Get a motherboard with a Z87 chipset so you can have the option to properly overclock your chip.
If you must get the Prodigy M, then go ahead. I don't recommend it as the layout causes a bad airflow problem: hot air gets exhausted out the bottom and rises back up into the case, therefore being inefficient and recycling some of the hot air.
PSU: A good 550W psu will be enough for a single GPU setup. I would go with a Seasonic or a decent rebranded one. Here's the one I always recommend: http://pcpartpicker.com/part/xfx-power-supply-p1550sxxb9
How about a second gpu in the future? I would have about 3 HDDs and 1 SSD along with it
Something like this: http://pcpartpicker.com/part/xfx-power-supply-p1750bnlg9
Cool, thanks.
Something else to consider with the Prodigy M is the space for the power supply in relation to the video cards. You mentioned a 290x which is going to be a long card, so it will cut into the space for the power supply. If you want to use that card you need a power supply that is less than 6" or 150mm long. I did a lot of digging and the only power supply that I could find that could handle 2 gpus and still fit is the Cooler Master GXII.
