Sorry to hijack,but how do you change the CAS timings in the BIOS? I've got that board with the 8350 as well but my ram is running at CAS 11. The kit says 9.What gives?
Go to bios > advanced > Ai Tweaker > Dram timing control. probably everything will set on auto you can set the right timings by hand, you have to look on the webpage from the manufacturer for the correct timings of your ram. probably 9-9-9-24. at 1.5V
I agree with this statement. 1600mhz w/ CAS of 9. If higher clocked memory is of a similar price, with a CAS of 10 or 11, I would be fine with that too.
I run 2x4GB Kingston HyperX Black 1600mhz. Looks beautiful, and picked it up on sale.
price for EVO 2.0 is around 105 bucks
bought today a Corsair brick and Corsair case and damn man, it feels solid!
yesterday i took apart my old broken pc and to my surprise i discovered a Creative sb 0570 sound card and 320gig Seagate Barracuda HDD:
so, will those work on my rig (asus m97 EVO 2.0)?
also i've got a CoolerMaster 4 pin 80mm fan in perfect condition, but my case doesn't fit 80mm, how can i attach this thing to my case?
thanks yall!
also, while i was at the store picking up the case and PS, i asked one of the manager if he could bios ASUS m97 mobo, he said: no can do
@Angel-
Thank you.Much appreciated.
By the way,do we enable XMP profile in the said area or is that enabled by default?
@OP-
Corsair brick? PSU,you mean?lol.
Yea,both those items will work with your board. Fit the card into the PCI slot and use a SATA cable to connect the HDD.
How many fans does your case already have?If i recall correctly,the EVO has only 3 chassis fan headers and the usual CPU fan header.
You said 2.0,right? Doesn't need to be flashed over.Your 8 core will work right off the bat. Once you have finished your rig and have it up and running,use the motherboard CD to install the utilities and let the utilities do their thing.
nah, i meant a first EVO 1.0, which is cheaper.
but aint got a DVD drive to boot up a CD :\
should have gotten a dell.
How much cheaper?You'll need another CPU to flash over with. Unless you know someone who will be willing to loan you the CPU,it'll be a hassle.If the price difference isn't too big,get the 2.0
No matter,download the utilities from the ASUS website.
well, i know a guy who could update my bios, but he lives 150km from me lol
ASUS M5A97 = 2850rub ~ 84$
ASUS M5A97 EVO R2.0 = 3609rub ~ 106$
97 or 97 EVO 1.0?
I'd get the EVO,at any rate. But it is your money and if you are willing to travel the distance...
lol i thought 97 and 97 EVO 1.0 is the same thing
i guess EVO 1.0 then
I love cats and your cat looks awesome
How old?
I know its diverting from your hardware topic but its your own fault for showing the pictures!
There are differences,my friend.
97:
http://www.asus.com/Motherboards/M5A97/
97 EVO:
http://www.asus.com/Motherboards/M5A97_EVO/
97 EVO R2.0:
http://www.asus.com/Motherboards/M5A97_EVO_R20/
lol, sorry, thats not my cat
found that pic on a russian 4chan
wish i had more pics of that cutie patootie :3
actually, yes, i've diged up some:
BTW this cat is 12-14 yrs old now
if i got a SATA 2 (1.5gig per second) HDD, can i attach it to SATA 3 ports?
and what should be disc0 and what disc1?
i guess disc0 is SDD and disc1 is HDD?
1. Yes, Sata 2 should be compatible with Sata 3.
2. I have no idea what you're talking about.
here:
http://youtu.be/0zOYdNEHDQo?t=55m13s
55:13
