Hello, I'm considering a new gaming rig as my current pc is now 6 years old. A part from games, it won't have to do anything fancy. Even then, I’m not too sure what frame rate etc I'm aiming for, I really just want the games to be playable. If I had to give a goal, the new rig should be able to plat Fallout 4 at 50FPS on at least medium settings.
To explain where I'm starting from, my current specs are:
ASUS P5Q-E
Intel E5200 Dual Core 2.50GHz
Zotac GeForce GTX
660 2GB
4GB DDR2
1TB WD Green 5400rpm
And I'm happy enough with the performance on the older Fallout games (3 & New Vegas) as well as Skyrim, Bioshock & RAGE.
My current plan is use my existing peripherals & GPU (Zotac GeForce GTX 660 2GB) and buy a G3258 to over clock. I intend to upgrade both in couple of years. My budget is approx €500. I'm based in Belgium, so I'm using the German pcpartpicker for pricing, but will likely buy from a mix of Dutch, German & French stores. Here is what I have come up with so far, http://de.pcpartpicker.com/p/CbyPTW ,
I can find the mobo for €151 (azerty.nl) and the PSU for €97 (amazon.de) so the build comes to €416 at the moment.
What do you think? Where can this be improved for the best results?
Thanks in advance for your advice.
