What will you be using this PC for? Gaming, editing, ETC...
Also do you already have the SSD listed above?
Get a WD Black drive instead of the Blue.
Mostly gaming bf4, skyrim and etc.
And no i dont.
Got ya
What site are you buying from and where do you live ?
I would change the motherboard to a H97 and *maybe* get a better psu and swap the gpu for a proper R9 290x / R9 290
It's closer to eleven hundred but it's worth every penny and it's probably you're best bet for a system.
http://uk.pcpartpicker.com/p/kjqTqs
i think i am not going to overclock so i think i could get a cheaper cpu and a motherboard.
And why would you grab a black instead of a blue?
i dont see any vallid point for that to be honnest ☺
Black is faster
nope...
its just a big load of marketing BS. lol ☺
[[{"type":"media","view_mode":"media_original","fid":"116237","attributes":{"alt":"","class":"media-image","height":"261","width":"349"}}]]
well, what kind of build would you recommend then?
you build looks good to me except the motherboard.
That Xeon 1231V3 is a haswell refresh chip, and will most likely not work on a B85 chipset board out of the box. I would recommend a H97 board instead, because that will work guaranteed.
Something like Asrock H97 Fatal1ty performance or what not. ☺
ok, thanks for the suggestion!
