wondering what GPU would be best for 3d modeling
Quattro 600 or 620
or a gaming gpu such as the gpu
The GPU is going to be entry level. sorry.
http://www.amazon.com/PNY-Video-Graphics-Cards-VCQK620-PB/dp/B00MPXS3RW/ref=sr_1_1?ie=UTF8&qid=1421971557&sr=8-1&keywords=k620
looking at that one
thanks for the help guys!
I do not do much 3d modeling so take this with a grain of salt. I think a gtx 750 ti would be much better compared to the 620. It has much faster memory and depending on the model can be cheaper. Personally if it was my system I would get a gtx 750 ti ASUS strix edition.
My source
http://gpu.userbenchmark.com/Compare/Nvidia-Quadro-K620-vs-Nvidia-GTX-750-Ti/2840vs2187
quadro 4000
http://www.amazon.com/PNY-DisplayPort-Profesional-Graphics-VCQ4000-PB/dp/B003X26T70/ref=sr_1_2?ie=UTF8&qid=1421980541&sr=8-2&keywords=quadro+k4000&pebp=1421980546958&peasin=B003X26T70
is the budget quadro *maybe worth getting ... but if all you are doing is 3d .. get a gaming card. 95% of the time you won't need a quadro
What software are we talking about? What does it support? CUDA or OpenCL or Both? If CUDA only: Quadro 4k. If OpenCL only: AMD FirePro W5000. Both CUDA and OpenCL: Firepro W5000 or higher.
http://www.newegg.com/Product/Product.aspx?Item=N82E16814105007
