So I'm setting up my own Water Cooling loop for my CPU: i7-3770k. I've chosen the EK-Supremacy Full Copper 1155 CPU waterblock & the Coolgate 3x120-60 Full Copper Radiator.
Ek waterblock: http://www.techbay.no/product.html/ek-cpu-vannblokk-ek-supremacy---full-copper?category_id=111
Coolgate radiator: http://www.techbay.no/product.html/coolgate-radiator-3x120-60-cu-belagt?category_id=181
What I don't know is what type of fittings would you guys (or girls) reccomend that I use. I have looked online and it seems like Compression fittings are the most used & most secure. What size of tubing gives best flow and are best fr this waterblock and radiator.
I also haven't decided on what reservoir and pump to use. I have a Cooler Master Cosmos II Ultra Tower case with plenty of space. I would desire a good pump here. and what Coolant do you reccomend.
