So to start off I'll give you my current setup, and then what I plan to build.
Current Setup: http://pcpartpicker.com/p/2vafv
New Portable Setup: http://pcpartpicker.com/p/2tAhn
I'm looking at using an AMD 750k processor with a Asus GTX 760 inside the Lian-Li TU200B case similar to the Colugo rig. There are not a lot of options for a mini-itx setup for AMD, but I thought that the FM2 socket with the 750k shouldn't be too much of a problem. I travel a lot due to the military, and would like to have a full setup wherever I go. I currently just use a TV for a monitor and when I travel around the states I usually have access to some sort of TV. Obviously this won't be going to any combat zones, but it should help when I move around in CONUS. I will not be doing any rendering, simply a gaming/casual media consumption rig. I don't mind playing games like BF4 on High/Medium graphics, but if this rig can't even handle that I might opt for the Intel/MSI mobo instead.
What do you guys think?
Well, I'm going to assume you don't want to take apart your setup you have now, so..
Spec-wise everything looks great. I'm not too familiar with the specifics of that Lian-Li case, so I'll wait for someone else to chime in.
The case is almost the exact same one that Logan built for the Colugo project, but instead of the TU100 case its the TU200B. Not real sure what differences there are between them. I will most likely sell the setup I have, the only thing I might keep is the SSD for the OS. And the Blu-Ray Writer I bought when I built it was a complete waste, not exactly what I was looking for at all.
I was also looking at the Sapphire R9 270x to put in the case, it has a pretty short PCB.
What's drawing you towards the AMD build? Budget?
Budget is more-so the reason, but I don't need the productivity power of an Intel based system. All I'm really wanting to do is play games and watch movies.
You can part out some stuff in your current rig, buy a new motherboard and GPU if you want better performance, and build it in the Lian-li case. Then you can sell some of your old components and have a nice Intel rig.
