Are you sure you want to spend $3000? That's a lot of money and completely overkill for most people I feel. I tried making this build expensive and it still comes in $1000 under budget: http://ca.pcpartpicker.com/p/ZY3z99
EDIT: Here's the link for MemoryExpress only: http://ca.pcpartpicker.com/p/Vm6cFT
Anything higher end and I think you might as well just burn your money in a fire because gaming doesn't actually require a whole lot. On the bright side the build I pieced together gives you the ability to overclock in the future if you desire, but will still be more than strong enough stock. It's also mostly colour matched if you're into that sort of stuff.
Thank you so much, I had no idea this was the case.
I was just wondering if i wanted to have 980s instead? due to preference issues forgot to add that in :(
Using the same build I posted earlier a single 980 will come in at just under $2200 and two 980s will be just under $2900. A single 980 is very powerful as it is and two of them would would probably max out pretty much any game currently available even playing at 4K: http://www.anandtech.com/bench/product/1351?vs=1075
Pretty much anything will work for LoL and DoTA 2 though.
Here you go. I added a couple good merchants since limiting yourself to MemoryDirect really nerfs the stuff you can get. I recommend taking a look at running Linux since you stated you mainly play MOBAs like LoL and DOTA 2 both of which are available on Linux.
PCPartPicker part list: http://ca.pcpartpicker.com/p/36RND3
Price breakdown by merchant: http://ca.pcpartpicker.com/p/36RND3/by_merchant/
- CPU: Intel Core i5-4690K 3.5GHz Quad-Core Processor ($309.99 @ Memory Express)
- CPU Cooler: Noctua NH-D15 82.5 CFM CPU Cooler ($119.99 @ Memory Express)
- Motherboard: Asus MAXIMUS VII HERO ATX LGA1150 Motherboard ($259.99 @ Memory Express)
- Memory: Kingston Fury Black Series 16GB (2 x 8GB) DDR3-1866 Memory ($177.98 @ Newegg Canada)
- Storage: Crucial M550 512GB 2.5" Solid State Drive ($299.99 @ Memory Express)
- Storage: Western Digital BLACK SERIES 2TB 3.5" 7200RPM Internal Hard Drive ($159.99 @ Memory Express)
- Video Card: Sapphire Radeon R9 290X 8GB Vapor-X Video Card (2-Way CrossFire) ($581.98 @ Newegg Canada)
- Case: Fractal Design Define R5 w/Window (Titanium) ATX Mid Tower Case ($139.99 @ Newegg Canada)
- Power Supply: SeaSonic Platinum 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply ($289.99 @ Newegg Canada)
Total: $2921.87
Prices include shipping, taxes, and discounts when available
Generated by PCPartPicker 2015-02-02 02:48 EST-0500
