Hi
i want to build a gaming pc but I have a budget of $600 australian dollars.
i've been lokking on newegg for some parts and this is what i've found
case: http://www.newegg.com/Product/Product.aspx?Item=N82E16811144197
HD: http://www.newegg.com/Product/Product.aspx?Item=N82E16822148840
Motherboard: http://www.newegg.com/Product/Product.aspx?Item=N82E16813157319
GPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16814161402
I plan on buying just one hd 7770 first and getting another one soon
CPU: http://www.newegg.com/Product/Product.aspx?Item=N82E16819103727
Ram: http://www.newegg.com/Product/Product.aspx?Item=N82E16820231550
I alson plan on upgrading the ram in the future.
PSU: http://www.newegg.com/Product/Product.aspx?Item=N82E16817190030
I would appreciate if someone knowledgeable could help me out and tell me if these parts are all compatible with each other and if i need to buy a crossfire bridge if it already doesnt come with the mobo
Thanks alot
